Aircon(and heat) wasn't working this morning
Aircon(and heat) wasn't working this morning. I ran a quick errand and it never came one. I turned the car on again, no luck, and then I accelerated up a hill and it suddenly worked. Any idea what might be going on?
Since you are referencing both the ac and heat, are you just talking about the blower? You're not saying the air is blowing but is neither cold when on ca or hot when on heat.
Originally Posted by resharp001
(Post 4363875)
Then yes, you are talking about the actual blower, not necessarily the ac or heat. We seem to have some finicky blowers. I had to replace mine about 6 months after buying my jeep brand new back in 2013. Every once in a blue moon the blower will cut out for 10 seconds or so and come back just like nothing happened. If this is something that continues happening, I think I'd look at the blower motor itself. I'd think less likely that it would be the control switch or fan resistor (what controls the fan speed setting when you turn the knob). I think for now I'd cross my fingers and hope it was just a one-time odd occurrence. It seems back when I had to have mine replaced, it was cutting in and out fairly often.
(Post 4363882)
I have not dug into mine, but I believe, from a different thread, you're just talking a ~$70 part, 3 bolts, and an electronic connection, so not a difficult swap if that is the case.
