Antifreeze?
Now, what were you saying about protection of your warranty at five years?
Just ensure that whatever you get is one hundred percent compatible with Chrysler products. Most antifreeze out there is NOT. If you don't believe what I've just written, do some research. It is completely correct, and using the wrong anti-freeze will cause significant degradation of cooling performance, as well as corrosion and early parts failure. Honest.
My question was rhetorical. I meant for you to understand that if you select the wrong antifreeze, which is easy to do, you place your lifetime warranty at greater risk than if you wait until 102K miles to change the antifreeze.
Radiator water flow
The new GM engines cools the heads first (To comply with feds regs on emissions) They do this to make a hotter combustion to meet the regs) water thru the heads first then down thru the block and back to the radiator, My MH 6.0 is this way, and it works great, I tow thru the desert when its 110 + out and have had no problems with cooling, when the AC and everything is on.
I wonder if our little JK 3.8 is this way ?
33
33
Radiator water flow
33
33
So what is the correct antifreeze for these vehicles?
Will this stuff work?
http://www.amsoil.com/storefront/ant.aspx
