any issues removing passenger front seat?
Old Aug 21, 2010 | 04:57 PM
Basic13's Avatar
Default any issues removing passenger front seat?
I need a little more room to haul a few things. Looks like there is just one torxe bit holding on the seatbelt a 4 bolts holding the seat in place. Any other issues I need to be aware of when removing the passenger seat?
Old Aug 21, 2010 | 07:26 PM
ronjenx's Avatar
Does your seat have an electrical connector underneath for a side air bag/occupant sensor?
If so, you need to disconnect the battery negative terminal to allow the air bag capacitor to deplete, BEFORE you disconnect the plug.
Old Aug 22, 2010 | 03:24 AM
eric1213's Avatar
i removed my front seats to install seat heaters, no problems with removing the seats, pretty straight foward
Old Aug 22, 2010 | 01:43 PM
Mike Davis's Avatar
Default seat removal
I needed all the torque I could muster. I do believe the bolts have some thread sealant on them from the factory. Slow steady pressure and they'll come loose.
Old Aug 22, 2010 | 02:22 PM
falconfixer's Avatar
There is a generous amount of Loctite on the bolts securing the seat to the floor and also on the bolts securing the seatbelts. I used a 1/2" drive breaker bar and the handle from a jack on the end of it to give me hella leverage. Came out like butter.
I'd recommend on install to apply blue loctite to the threads and torque to recommended settings. I can't remember off hand but I want to say 150 ft lbs.
