Any other "07"s need piston rings
Old Nov 17, 2010 | 08:39 AM
  #21
Reiper's Avatar
Originally Posted by Slightlymodified
My 08 is starting to use more and more oil. at 13,000 miles it was down a couple quarts at my oil change with 3000 miles on the oil. Now it is using closer to 3 and the dealership says this is normal? They did find the intake gasket leaking, but my whole motor would be covered with that much oil leaking. My old 70 Blazer with over 200,000 miles on it burns less oil than my Jeep. I don't understand how a quart every 1000 miles could be considered normal.
Have them start an Oil consumption test maybe if enough of us do this the problem will get fixed
Old Nov 17, 2010 | 08:41 PM
  #22
racin444's Avatar
X2 on that!
Old Nov 18, 2010 | 10:24 AM
  #23
Christine's Avatar
Geez, all this talk is making me nervous. I bought my 07 used with 9K miles on it. I now have 12K on it. Should I be doing anything besides religious oil changes?
Old Nov 18, 2010 | 10:37 AM
  #24
humdezign's Avatar
Mine may, refer to my post here. not sure whats wrong yet but dealer says i need a new engine!
Old Nov 21, 2010 | 06:35 PM
  #25
Reiper's Avatar
Just dropped the Jeep off at the Dealership so they can fix what ever is wrong tomorrow whether it's the piston rings or valves we'll see.
I would like to thank Wayoflife again for posting this e-mail address gualberto.ranieri@chrysler.com I used it and Chrysler called within a few days
Chrysler does read this forum the case worker that called me made reference to my posts
Old Nov 21, 2010 | 06:40 PM
  #26
Slightlymodified's Avatar
Started an oil consumption test on my 08. What is messed up though is that they overfilled it by a 1/2 quart.
Old Nov 21, 2010 | 06:56 PM
  #27
Reiper's Avatar
What's up with that... would that be so the oil is a 1/2 quart higher when you have your 500 mile check up.......... isn't that cheating on a test
Old Nov 21, 2010 | 07:34 PM
  #28
CAM24's Avatar
I'm sure that's why they did it, haha. The first dealership I went to for the oil consumption test gave me the run around. They were definitely up to something shady. I decided to try another one...going in Tuesday for them to check the levels.
Also, the dealership I went to this time said the 3.8 takes 5.5qts of oil. What's up with that? Even the manual says it takes 6, which is what I've always put in it.
Old Nov 21, 2010 | 11:53 PM
  #29
JKlad's Avatar
The sump holds 5.7 liters, which is 6 quarts.
Old Nov 22, 2010 | 04:22 AM
  #30
MM Jeep's Avatar
Originally Posted by jkman77
could the rods being installed wrong be the cause of my start up knock? i was told it sounded like the oil was taking too long to get to the lifters. the noise is more of a loud ticking than a knock.
My Jeep sits during the week while I work. When I start it on the weekend to go out exploring it sounds kinda awful starting the first time that weekend. Each restart the same weekend is quieter. It only has 6,500 miles on it My 2000 Silverado has never made noises like this thing and it sometimes sits two weeks or more between starts!
Yep, Im a vehicle junkie the more the better
Good thing there is a 5 year 100,000 mile power train warranty.
Now I wonder, would Chrysler void my warranty if I change to 5w30 to help combat this start up noise
Sorry not intending to hijack but it seems this is yet another oil control problem with the 3.8
