Auto trans fluid usage
Old Feb 6, 2011 | 06:05 AM
Lomax-dtl's Avatar
Yesterday I noticed that when I started my jk there was like a burning smell. Then I checked the engine oil and was fine but the trans was a whole quart low of fluid. No leaks that I can see. Anyone have an idea of what the problem is????
Old Feb 6, 2011 | 06:19 AM
ronjenx's Avatar
Where on the stick did it read?
Did you give it time to reach operating temp before you checked the transmission fluid level? If not, it will be low on the stick.
Old Feb 6, 2011 | 07:07 AM
Lomax-dtl's Avatar
Yes I did it was a good ways below the hot.
Old Feb 6, 2011 | 07:18 AM
ronjenx's Avatar
I don't think anyone has reported loss of automatic transmission fluid without it being a leak.
If the fluid you saw on the stick is still a good color, and doesn't smell burnt, there only two possibilities:
It was low all along
There is a leak you haven't seen
Before you top it off, drive for 10 minutes or so, and check it again.
Old Feb 6, 2011 | 07:25 AM
Lomax-dtl's Avatar
Okay will do thanks, I'll try to take a better look at it do u think the skid is catching the leaking fluid ??? So there for I wouldn't see it
Old Feb 6, 2011 | 09:06 AM
Dronac's Avatar
Check the transmission cooler lines. Mine were just replaced last week.
Old Feb 6, 2011 | 11:34 AM
mkjeep's Avatar
Umm, what they said and also check it while in neutral, tends to show lower if in park. Unless you already did that.
Old Feb 6, 2011 | 07:43 PM
Lomax-dtl's Avatar
Yes I checked it while it was in neutral and it was still low. So I've got no idea what caused it?
Old Feb 6, 2011 | 07:46 PM
Lomax-dtl's Avatar
Could that cause it to be low?
Old Feb 6, 2011 | 07:54 PM
Lomax-dtl's Avatar
Originally Posted by Alien10
What year is your JK and how many miles?
It's an 09 rubicon with 24,000 miles.
