Auto trans question
My reverse feels very "loose" - not quite sure how else to describe it. If I'm pointing downhill and put it in reverse to back up, when I take my foot off the brake it will roll forward and almost feels like it's in neutral until I give it a lot of gas - I have to get the rpm up to around 3k before it will stop rolling forward and start backing up the hill. I don't think it was always like this (maybe it was, but I never noticed it until recently).
Is this normal? Is there anything in the trans that can be adjusted for this?
Originally Posted by Labrador
I hold the e-brake, then release it when it starts to move...
Originally Posted by jeep08ham
Have you checked the oil level?
I haven't looked at the jeep's reverse gear setup, but some transmissions use a gearing between the first and second gear's ratio - which means it takes more powere delivered to make it move backwards - this makes it "harder" for the torque converter to overcome the force of gravity pulling the vehicle downhill. The converter will therefore 'flash' to a higher speed before the engine can deliver the power through the transmission to the wheels. (anyone out there know the ratios of the trans??) SO - is this normal - probably, but I haven't personally driven your jeep so I can't say for sure....
Also - Labrador - why in the heck would you be pulling the e-brake on an auto - unless you don't have a left foot... simply use the left foot on the regular brake and the right on the skinny pedal and feather the gas "on" and the brake "off" to prevent rolling more downhill.
x3 - I start Jeep in my level garage, put it in reverse and take my foot off brake. Jeep will not move till I give it some gas and increase rpm's. All oil levels are OK.
I just think it's a automatic transmission "Jeep thing".
I'll be checking this thread in case it's not normal and someone has a solution.
