View Poll Results: How is your Automatic transmission treating you?
I have NO problems, my transmission works great
85.24%
I am starting to have problems requring a visit to the dealer
9.84%
My transmission is a constant problem and has already been to the dealer
4.92%
Voters: 1199. You may not vote on this poll
Automatic JK Transmission Problems POLL
Old Aug 4, 2013 | 07:52 AM
  #291
Labrat0116's Avatar
Thumbs up
I'm sure this buried in this thread somewhere but here it is again.
2012-2013 Jeep Wrangler Recalled For Transmission Problem
Old Aug 4, 2013 | 05:16 PM
  #292
Jiblet's Avatar
Originally Posted by redunlimitedguy
I have a 2013 jku with the auto and I have a problem with it I think. When I am taking off it acts like it wants to shift but doesn't. Rpms drop some but no gear change. Any thoughts would be helpful. Thanks everyone
That sounds like low ATF. Have you checked the level? (while hot)
Old Aug 7, 2013 | 05:16 AM
  #293
redunlimitedguy's Avatar
Will check this evening. Thanks for the input.
Old Aug 7, 2013 | 06:35 AM
  #294
DadsCJ's Avatar
No problems here and 15K hard miles...............
Old Dec 1, 2013 | 01:51 PM
  #295
gvanjvan's Avatar
60,000 miles and works like a charm
Old Dec 17, 2013 | 04:36 PM
  #296
branJK4's Avatar
45000 miles and transmission failure. Waiting for my warranty inspector to go out and approve the fix. Fingers crossed
Old Dec 17, 2013 | 04:52 PM
  #297
PAShadowJK11's Avatar
Just sold my 11' jku 2.5 in lift for last 24k miles 35's last 18k with 72k miles and tranny still shifted great..nasty shutter in reverse though shook so hard it would make your teeth chatter! Here is to hoping my 14' 2 door auto out performs it's predecessor...
Old Dec 19, 2013 | 10:17 AM
  #298
bombout800's Avatar
Sounds like an apply piston or servo is shot. Could also be issues with the valve body being clogged. Even the smallest contaminate that clogs or stops a valve can cause issues. I would get someone who knows their stuff to pull the pan and give the valve body a good once over and go ahead and replace small parts.
Old Dec 20, 2013 | 06:46 PM
  #299
nkotb's Avatar
2014 JKUR won't 2-3 upshift sometimes unless I let almost all the way off the gas. Its better when warmed up & worse when cold. :-(
Old Sep 27, 2017 | 12:05 PM
  #300
Tactical_Geek's Avatar
Veteran: Marine Corp
Reviving this old thread as I don't feel it necessary to start a new one. My 2008 JKU with the 42RLE acts up sometimes. I noticed the car lot I purchased it form did a flush and filter change which might be part of it. I tried a couple of methods to reset the transmission via disconnecting the battery and draining all power from the system but it hasn't helped.
It seems common but wondering if there's anything to worry about as most threads just die off. My shifts from 2nd to 1st are often jarring with a loud clunk. It happens mostly while slowly decelerating in city driving. Same thing the other direction if I'm just slowly mall crawling, it'll decide to shift from 1st to 2nd with a loud clunk and you can really feel it hit into the gear. Now if I'm accelerating any more than minimal throttle it shifts nice and smooth, and if I'm braking decently hard it downshifts smoothly as well.
From what I've seen I might as well let it ride, but wondering if anyone had any other advice.
