automatic transmission fluid capaity
Old Feb 3, 2008 | 10:50 AM
bear194's Avatar
Question automatic transmission fluid capaity
hi,just wondering if anyone knows how much transmission fluid it takes to fill an automatic?I can,t seem to find it in the manual.Thanks
Old May 17, 2008 | 10:35 AM
Jeep-N's Avatar
Automatic Transmission, Initial Fill..........4.0 quarts
With ENG at operating temperature, shift through all
gears. Check fluid level in NEUTRAL and add fluid
as needed.
Old May 17, 2008 | 11:24 AM
skibum's Avatar
as needed.
Interestingly enough, the writing on the dipstick says to check it in "park" and, at least on mine, there is a significant difference in the fluid level.
Old May 17, 2008 | 12:31 PM
ronjenx's Avatar
This is from the service manual:
TRANSMISSION FILL
To avoid overfilling transmission after a fluid change or overhaul, perform the following procedure:
1. Remove dipstick and insert clean funnel in transmission fill tube.
2. Add following initial quantity of Mopar® ATF +4 to transmission:
a. If only fluid and filter were changed, add 3 pints (1-1/2 quarts) of ATF +4 to transmission.
b. If transmission was completely overhauled, torque converter was replaced or drained, and cooler was flushed, add 12 pints (6 quarts) of ATF +4 to transmission.
3. Apply parking brakes.
4. Start and run engine at normal curb idle speed.
5. Apply service brakes, shift transmission through all gear ranges then back to NEUTRAL, set parking brake, and leave engine running at curb idle speed.
6. Remove funnel, insert dipstick and check fluid level. If level is low, add fluid to bring level to MIN mark on dipstick. Check to see if the oil level is equal on both sides of the dipstick. If one side is noticably higher than the other, the dipstick has picked up some oil from the dipstick tube. Allow the oil to drain down the dipstick tube and re-check.
7. Drive vehicle until transmission fluid is at normal operating temperature.
8. With the engine running at curb idle speed, the gear selector in NEUTRAL, and the parking brake applied, check the transmission fluid level.
CAUTION: Do not overfill transmission, fluid foaming and shifting problems can result.
9. Add fluid to bring level up to MAX arrow mark.
When fluid level is correct, shut engine off, release park brake, remove funnel, and install dipstick in fill tube.
This is from the Owners Manual:
To properly check the automatic transmission fluid level,
the following procedure must be used:
1. Operate the engine at idle speed and normal operating
temperature.
2. The vehicle must be on level ground.
3. Fully apply parking brake.
4. Place the gear selector momentarily in each gear
position ending with the lever in P (Park).
5. Remove the dipstick, wipe it clean and reinsert it until
seated.
6. Remove the dipstick again and note the fluid level on
both sides. The fluid level should be between the HOT
(upper) reference holes on the dipstick at normal operating
temperature. Verify that a solid coating of oil is seen
on both sides of the dipstick. If the fluid is low, add as
required into the dipstick tube. Do not overfill. After
adding any quantity of oil through the dipstick tube, wait
a minimum of two (2) minutes for the oil to fully drain
into the transmission before rechecking the fluid level.
NOTE: If it is necessary to check the transmission below
the operating temperature, the fluid level should be
between the two cold (lower) holes on the dipstick with
the fluid at approximately 70° F (21° C) (room temperature).
If the fluid level is correctly established at room
temperature, it should be between the HOT (upper)
reference holes when the transmission reaches 180° F (21°
C). Remember it is best to check the level at the normal
386 MAINTAINING YOUR VEHICLE
Old May 17, 2008 | 03:41 PM
skibum's Avatar
Exactly. So which is it? My dealer can't answer the question (nor can two others in the area).
Old May 17, 2008 | 04:10 PM
ronjenx's Avatar
The service manual also says the torque converter fills in both park and neutral. It should not make a difference, then. I would go by the owners manual because that is what was sent with the Jeep and it is what we are expected to comply with.
