Automatic transmission fluid - Where to put it in?????
Old Jun 11, 2011 | 04:09 PM
Jeepurz's Avatar
Default Automatic transmission fluid - Where to put it in?????
Gawd this is embarassing........but I can't figure out where you put in new AT fluid in my 2008 JK, I find all the other fill pipes, but all I find under the hood is the AT fluid dip stick. I can't imagine you would fill it thru the dip stick pipe.
Please give this bozo the honor of your answer........thxxxxxxxxx.........
(oh yea, can't find the manual either)
Old Jun 11, 2011 | 04:21 PM
Markdsv's Avatar
Default Transmission fluid top up through dipstick close to bulkhead
Hi, you basically add transmission fluid though the dip tub close to the bulk head of your jeep (Yellow knob) NOT the engine oil dipstick !
Just just a funnel to get the fluid in, I topped mine up a couple of weeks ago as I installed a transmission cooler,
Hope this helps.
Cheers,
Mark
Old Jun 11, 2011 | 04:22 PM
Mark Doiron's Avatar
Have a stick, so can't answer your primary question. But, if you go to Jeep.com you can download the owners manual for free.
Old Jun 11, 2011 | 05:37 PM
mabar's Avatar
Yep, you add auto transmission fluid through the dipstick. Yellow plastic handle dipstick near the firewall at the rear of the engine.
Be sure to use ONLY ATF-4 fluid. Can be Mopar, Valvoline, Walmart brand, or Castrol, but MUST be ATF-4.
Mabar
Old Jun 11, 2011 | 05:49 PM
ronjenx's Avatar
Licensed ATF+4® Brands as of March 25, 2011.
Advance Auto Parts ATF+4®
Auto Extra ATF+4®
Auto Zone ATF+4®
Carquest ATF+4®
Castrol ATF+4®
Castrol Transmax ATF+4®
Chevron ATF+4®
Citgo Transgard ATF+4®
Coastal ATF+4®
Federated Auto Parts ATF+4®
Great Wall ATF+4®
Havoline ATF+4®
MAG 1 ATF+4®
Mobil ATF+4®
Mobil Super ATF+4®
Mopar ATF+4®
NAPA ATF+4®
Northland ATF+4®
O’Reilly ATF+4®
Parts Master ATF+4®
Parts Plus ATF+4®
Pennzoil ATF+4®
Pennzoil S6 ATF+4®
Petro-Canada ATF+4®
Pure Guard ATF+4®
Quaker State ATF+4®
Quaker State S6 ATF+4®
Ravenol ATF+4®
Service Pro ATF+4®
Sinopec ATF+4®
Shell Spirax S6 ATF+4®
Super Tech ATF+4®
Valvoline ATF+4®
