safe to lift jku w 3 ton jack?
I will usually jack under the control arm mounts to set jackstands under the axle, and i do this one at a time, then lift from the rear diff to get jackstands under the axle there. This is of course to lift it only a small amount. For full on lifting, ill use jackstands on the frame all around and still keep jacks front and rear.
Originally Posted by speed2005
No f ING owners manual in my 2011
There is a torque sheet on project jk
http://project-jk.com/jeep-jk-write-...orque-settings
80-125 ft lbs
