Aux tanks?
I'm thinking about rear bumper that carries two 5 gallon jerry cans, but maybe there's enough space under the JK to add a 10-15 ga aux tank? This possible? If so does somebody make an aux tank for the JK or is this a lame idea?
Mik
Mik
Seriously, gasoline has a pretty high vapor pressure, and the vapors are explosive and very easily ignited. In a gasoline engine this vapor mixture explodes and drives the car when ignited by a tiny spark. So you really want to be careful with huge amounts of gasoline on a vehicle. If the fuel tank (or one of the tanks) ruptures the vapors can build up and be ignited by a small flame or spark. Diesel has a pretty low vapor pressure, so even if it does get spilled the vapors are not going to be building up in the surrounding air. And even if they do build up to a significant degree the flash point of diesel is WAY higher than that of gasoline. Gasoline can catch fire from a flame at -45*. Diesel needs to be over 143*.
Mainly it is just safer to have a large amount of diesel than a large amount of gasoline.
