Sponsored by:
Sponsored by: DashLynx
View Poll Results: Has your axel seal failed? Take the freaking poll!
Yes one has!
190
39.09%
Both failed!
50
10.29%
No, nothing yet.
235
48.35%
Whats an axel seal?
11
2.26%
Voters: 486. You may not vote on this poll
Axel seal problem poll.
Old 02-11-2016, 06:44 PM
  #171
BLACKWOOD's Avatar
Dana 30. Driver side inner axle seal. 70k No abuse on front dif.
Old 02-12-2016, 06:57 PM
  #172
Jeepinjim's Avatar
I have a 13 JKU and have some sweating around where the axel housing goes into the diff on my Dana 30. No drips what should I do?
Old 02-13-2016, 12:38 PM
  #173
SHOELESS's Avatar
Right rear failed @ 15,000 miles.....
Old 02-13-2016, 01:28 PM
  #174
jadmt's Avatar
the axle seals are covered under the 5 year 100000 mile drivetrain warranty. take it in and have it looked at or at least documented.
Old 02-13-2016, 05:13 PM
  #175
Jeepinjim's Avatar
The service writer told me about it when I was in on Tuesday for oil change. The tech said it was leaking, and the service advisor said it was "sweating" should I pursue a fix or just keep an eye on it?
Old 02-13-2016, 05:43 PM
  #176
jadmt's Avatar
they don't get better only worse so while they wont strand you just because they are leaking they can cause a mess. I like things right so I would get it fixed.
Old 02-13-2016, 05:48 PM
  #177
Jeepsg2012's Avatar
My right rear failed on my 2012 sport 2door at 20,000 but they only replaced the seal under warranty I had to pay for the brake pads that were soaked in oil :/
Old 02-13-2016, 08:43 PM
  #178
TreyJK's Avatar
Driver side failed at 95k miles, no other internal mods. Just cleaned up the tubes, replaced the guides, and installed Synergy seals. No more leaks! (Knock on wood)
Old 09-18-2016, 04:56 AM
  #179
Jahamm88's Avatar
Front D30 driver side failed at around 30k. Pre-lift and adventure driving. Dealer supposedly replaced both and have had no issues last 5k
Old 09-27-2016, 09:35 AM
  #180
crzyamerican's Avatar
Wife's 2013 JKU driver front just failed. At the dealer getting it fixed. Just went over 20,000 miles
3 inch lift, Tires are the same diameter as stock only slightly wider.
Quick Reply: Axel seal problem poll.
