Axle u joints bad at 41000 miles out of warranty chrysler will only cover 50%
Are you the original owner of your 2009 JK, with no mods that would impact the u-joints?
If so they should cover the entire cost.
If not, 50% is a good deal, if they don't jack up the price to begin with. (Unless, of course you can do it yourself.)
No not original bought with 3000 miles on it
A cheaper alternative might be pull your half shaft out with the bad u-joint and take it down to Pep Boyz or some other local shop and have them press a new u-joint in. They did mine for $60 took about 1/2 an hour.
New lifetime warranty u-joint at Napa autoparts was $30 (Duralast GOLD U-joint. PN 1-0297DG.)
So less than a $100 total and I had the Jeep all buttoned up and back on the road in a couple hours.
Pulling the axle shaft was easier than I thought it would be. Basic hand tools and a rubber mallet, 15-20 min tops to remove.
