Back Window
I don't like to leave the back window on and rolled up with the top down.
I could not get it to come loose. I mean I can not get the top out of the two zippers once they are on the same side and the window is just hanging there.
Any suggestions?
Zip to the left or right.
I don't remember having this trouble with my 04.
Thanks
Any suggestions?
Thanks
Make sure the soft top is adjust right. Sometimes the two parts that connect to the rear get stretched out or pushed in a bit that makes it hard for the zipper to move. You could also check to ensure that the zipper didn't get messed up last time you zipped up. If all else looks good try a very small amount of WD-40 on the zipper to get it started.
It zips from the left to right. Bring both to the left side and all the way down. Then pull bar out of clips on rail. You should now be able to pull the window out.
I wouldn't roll up the window at anytime, you will end up with scratches-FYI..
