Backup Light
I searched on this topic but hadn't seen anything more current than 2011, so here goes. The reverse light in the OEM tail light is laughable when you really need to light up the space behind you. Has anyone found a bulb replacement that is brighter than the standard 3057/3157 incandescent? I don't want to have to install a $300 lighting system just to do the job the OEM bulb should do in the first place. And I don't want to cook the plastic light housing with an unsafe bulb either.
Thanks in advance! :beer: |
2 Attachment(s)
Walmart driving lights into the housings. Cost about 20 bucks I think.
Attachment 679800 Attachment 679801 Edit: found the link - https://www.jk-forum.com/forums/jk-w...ghting-214986/ Also added it to the cheap mods thread. |
See what worked for me. https://www.jk-forum.com/forums/jk-e...2/#post3868155
I popped in a set of Amazon.com: 2Pcs Aaron High Power White 80W 3157 XB-D Cree LED Light Bulbs Super Bright for Brake Backup Tail Reverse Turn Signal Lights: Automotive bulb replacements, they are brighter then the stock headlights. I also swapped my headlight bulbs out with an $80 HiD kit. I can now see at night, in drive and reverse.
Originally Posted by Mountain Man Tim
(Post 3979327)
Originally Posted by Ol' Bob
(Post 3979359)
Which hid kit did you use? I'm looking to upgrade my headlights in the fall but really don't want to drop 500 bucks on them.
(Post 3979327)
| All times are GMT -8. The time now is 05:31 AM. |
© 2026 MH Sub I, LLC dba Internet Brands
