Battery???
Disclaimer: I don't know if there's any truth to that or not. I'm just repeating something I read.
I just did some research and purchased a new battery about a month ago. I ended up with a yellow top optima due to price and basically one local parts store in my town.
However, besides the Optima you should consider:
Northstar
Oddessy
or the Diehard Platnum
I was looking for the Northstar or oddessy but have been happy with my yellow top!
Northstar
Oddessy
Northstar
Oddessy
Northstar
Oddessy
I have had a yellow top in my old YJ and old TJ with no issues- when my battery in my JK battery failed a few months back I once again with the yellow top- mainly as these batteries have never failed on my and have always been strong- everyone I know that has very trail worthy rigs use them ( some use blue). Oh and I live in colorado springs
Now along the same lines, about 2006 EnerSys, the company that manufactures Oddessey, (here in the US) singed a contract to provide the Sears DieHard Platinum batteries for Sears Corp. The Oddessey sells for about $268.00 The Sears DieHard Platinum sells for about $180.00, however if one looks up the specs for both these battery's, one will see the specs are identical. Again add 1+1 and get 2.
When the battery requires replacement in my XJ and the wifes JK Unlimited, both will be replaced with the DieHard Platinum.
Im trying to decide upon Optima or the Sears Die Hard for here in aurora and i am wondering what the colorado jeepers have said or used. After learning this im leaning more toward Sears
I think i understand this correctly. The new alternators and manufactures quest for better MPG are reducing the output voltage at low/city RPMS and also at times of high way usage cycle the usage of the alternator and also power steering from what i have found.
The problem is the new efficiency is not charging the Optima batteries properly with just city driving but require some higher RPM or prolonged drive times to properly charge the Optima brand batteries?
The same issue accurse with Systems such as windshield washer fluid heaters that automatically kick off to ensure the vehicle can start at a certain voltage say 12.7 volts but the new charging systems only charge at idle of 12.5V Thus the system never functions.
would it be safe to say the batteries are the same Jeep has changed with the JK model and Optima has not changed their design to work properly with the JK?
Traditionally, unless what you're saying is true, you should see over 13v with the engine running. With the engine off, you should see just over 12v from the battery.
