Bent axle
First indication is if it looks like wheels are either tipped in or out too much at the top .. Wheel alignment spec will confirm greatly out of spec camber figures.
Second, continuous oil seal leaks and possible axle binding and vibrations.
I first noticed my front axle just looked bent. It was bent, proven at a shop. It was bent so slightly, I have never done anything about it. I bet that was 7 years ago. There is really no other indication that it is bent and I have had no problems so, when I do I'll replace it !
Of course one can use a dial indicator to check axle flange run-out precisely, but usually a good eye ball will spot a significant problem.
A bent axle flange scuffs the tire rubber every rotation and causes excess tire wear on that particular tire -- Many years ago that's what led me find a bent axle flange on my old Ford 4X4. Obviously better to catch it before that happens...
I have noticed when the tires are straight forward, the passenger side is pointed ever so slightly to the outside. There was a leak at the passenger side axle onto the C. Took it to the dealership to replace the seal. Worked for a little while and started leaking again.
I will try the suggestions. I guess I might be in the market for a new front axle or new to me.
Front axle housing I have noticed when the tires are straight forward, the passenger side is pointed ever so slightly to the outside. There was a leak at the passenger side axle onto the C. Took it to the dealership to replace the seal. Worked for a little while and started leaking again. I will try the suggestions. I guess I might be in the market for a new front axle or new to me.
