Bent steering stabilizer causes death wobble?
I've read all the threads about death wobble. I understand all the main issues. The main takeaway I've seen is that steering stabilizer masks problems that cause dw. However my question is , can a bent/damaged/leaking steering stabilizer actually cause death wobble. Reason I ask is that my dw showed up after doing a 2.5" bb, adding spidertrax, and a 5 wheel rotation. I then took it wheeling and pranged the steering stabilizer pretty good. It's bent about 15 degrees at the shaft and appears to have pissed out the oil. I have a new stabilizer and flip kit ready to drop in, but my gut says that there must be something else going on that's causing the dw and I prefer to try to find that before replacing the stabilizer. I may try removing stabilizer completely first and driving it that way. Anyway, comments advice welcome
I tweaked the bracket that my steering stabilizer mounted to, which I didn't notice at first. Over time, the stabilizer began to fade, and the DW began. Straightened the bracket, replaced the stabilizer, and no more DW. If there is another underlying problem, it has not shown itself (yet).
Didn't look bent but don't have anything to compare it to.Ill take a look at that. I recall from prior forum readings I can do that in the driveway with some basic tools
Also, did you loosen ALL control arms and the trackbar before installing the lift, vigorously shake everything at ride height under the vehicles own weight, then tighten everything back up at ride height? If not I suggest loosening everything and doing that.
Yup, pretty simple to measure. Excessive toe in (which would happen if the tie rod was bent) could be a contributor.
