Best CB Location
There is a whole forum here on CB and ham radio. This thread should be moved there.
https://www.jk-forum.com/forums/jk-c...r-jeep-227276/
If you're using the CB very infrequently--more as an emergency--then it likely won't matter, but as a practice all radio equipment CB, ham radio, etc., should be wired directly to the battery.
Been using mine like this for 2 years and works great. Uniden actually says it's fine. I use it this way on the trail as do most of the people I go with. We talk a lot of smack on the trail with no issues.
I agree it's best to have it hard wired and I doubt company trucks and truckers use the power jack. If I did not remove mine I would hard wire but I hate having it in unless offroading
I'll admit the power port can sometimes be used to power a CB but I would always advise running direct power from the battery. You can put a connector on it for quick install and removal and tuck the connector up under the dash when the radio is out. Radios can leak RF signal back up the power feed. That can be detrimental when RF gets into the dash harness. I have seen some very strange things due to 'stray RF' over the years.
It it is a rather quick thing to run power wires to the battery for a ham or CB radio in a jk. I think I spent 10 minutes doing it. Plus, this leaves my accessory port open for other accessories. 30+ years of mobile communications has taught me that nothing beats a set of power wires (positive and negative) straight from radio to battery.
Anyway, just more info for consideration. Enjoy the jeep!
The choice to use a cigarette lighter adapter was not the issue here in this thread, even though this thread was mislocated apparently.
It's about locations inside the cab that are available. I've been installing CB's in vehicles for many years, and so I realize it's more about convenience and where there is some solid material to screw the bracket into, and so forth.
I was hoping for some ideas based on other peoples installations of CB's in 2013 Wranglers. Pictures would be nice. I have my own ideas but am willing to entertain others.
I used this bracket. Nice, clean, steady and doesn't mess up the trim in any way.
https://www.strikeforcezebra.com/cbg...detector_mount
