Blinker at warp speed.
Old Jan 22, 2009 | 08:36 AM
Rubidon's Avatar
Default Blinker at warp speed.
I was driving to work the other day, it was about 6 deg. out.
I came to my first turn of the morning, I put on my turn signal and it started blinking at least three times as fast as it should. After a while it went back to normal. Anybody else have this happen to them ?
Old Jan 22, 2009 | 08:41 AM
Snap-Off's Avatar
Unhappy
Only time that has ever happened to me is when a bulb went out in my rear blinker... why it went back to normal (or what your problem was) is a mystery to me
BaltChief's Avatar
I had an old car that would do this if a bulb was burnt out. Don't know if the jeep is the same or not.
Old Jan 22, 2009 | 08:42 AM
BaltChief's Avatar
Damn, I must be getting slow in my old age.....
Old Jan 22, 2009 | 08:43 AM
jkkat's Avatar
Must have had a bad connection in your rear bulb, also check for water in the tail light assembly.
Old Jan 22, 2009 | 10:08 AM
jeepguyinMS's Avatar
x 2. check your connections and bulbs. I had one loose turn light in my grill and it did the same thing. Fixed it and the clicking went back to normal.
Old Jan 22, 2009 | 10:37 AM
mkjeep's Avatar
Change the bulb, see what happens
Old Jan 22, 2009 | 12:35 PM
Rubidon's Avatar
I checked for the bulb, every thing is working and it hasn't done it again.
The water thing in the tail light I didn't check, that could have been.
Any way thanx for the replies.
Old Jan 22, 2009 | 12:44 PM
ronjenx's Avatar
Yes, the JK is the same. It will blink and click fast if the computer has detected a fault (bad bulb, bad ground, broken wire, etc.) through the CAN-Bus system. The clicking you hear is not a relay to flash the bulbs like in the old days. The computer flashes the bulbs. It also makes a mechanical "relay" in the cluster click so the thing sounds like what we are all used to hearing. It will also throw a code telling you which bulb is bad.
(edited to add a word)
Old Feb 1, 2010 | 05:42 PM
Jason18790's Avatar
mine just started the warp speed blink this weekend..... anyone find a surefire solution??
