blinking rear locker fails to engage
Old Nov 26, 2008 | 05:57 AM
  #21
robin's Avatar
Originally Posted by JackMac4
I'll go take mine off road this afternoon and see if its still doing it. I was moving while engaging, but not very far. That would be interesting if its just a sensor. It sounds like I just need to let the dealer deal with it, but I hate doing that - they are incompitent most of the time.
mine was doing exactly what you mentioned, it turned out to be the solenoid, the tech at the dealer swaped a solenoid with another rubi that was on the lot, and it worked right away. I hope this helps
Old Nov 30, 2008 | 09:50 PM
  #22
pinchichango's Avatar
Originally Posted by jeepnoob
Mine blinks but locks. Dealer says that's normal now. WHAT A JOKE! At least it's working....but why the blinking!
mine does the same thing. it blinks but once i get onthe trail it stops. maybe it doesnt engage untill it is in use.
Old Oct 23, 2009 | 07:26 PM
  #23
Matt08jk's Avatar
I just took mine in, both front and rear were blinking continuously.
They looked at it, had to talk to Chrysler Engineers, then told me the control module needed replacement?
Finally they called to say that it should be fine now but the indicators are still blinking, apparently "they" are working on an update for this that is not available yet. . . . Not sure what to believe.
Hope to pick it up tomorrow and test it out.
Old Oct 24, 2009 | 07:13 AM
  #24
n6on's Avatar
Has the locker worked at all since the cover was changed? Some claim the SOLID covers need some grinding to prevent this problem.
Just a thought
Old Oct 24, 2009 | 07:34 AM
  #25
justinstoffregen's Avatar
Default Sensor malfunction
I've had this problem before....twice. Each time it's the sensor and the dealership fixes it in one day. It's getting pretty old even though it's a quick fix. It's one of things that make me feel better about not getting a Rubicon. I don't think anyone with Eaton or OX ever have problems like this. Also, usually when the rear locker fails the sway bar disconnect sensor goes haywire too. Good luck.
Old Oct 25, 2009 | 03:25 AM
  #26
RubiConz's Avatar
Mine blinks but engages fine. Shady though.
Old Oct 25, 2009 | 09:58 AM
  #27
Matt08jk's Avatar
Ok, I got the rig back.
Went to test it out and the front works great, very quick to respond. The rear indicator takes alot longer but it does eventually engage and disengage with a much more blinking in between. This is an Jan 10th 2007 build but it is new to me. Are the lights supposed to turn solid quickly?
The repair sheet says they replaced the Totally Integrated Power Module (TIPM).
