Bluetooth Uconnect playing music files at 2x or 3x speed?
Old May 17, 2012 | 06:50 PM
xsdbs's Avatar
Noxian,
That issue was only on the 2011 vehicles with the RES, REQ, RHB or RBZ radios and built prior to 6-1-2011 and the TSB update last year cured that issue.
For the MY12 vehicles, (with the same radios listed above) there is an enhancement TSB update that was released a couple months back. It's supported vehicle build date is prior to 1-1-2012. So the vehicle above that was built in March 2012 would have the most current SW in it.
Harman had an update for their radios last year also and I believe they had another update for the 2012 vehicles earlier this year. I believe the current SW version for the Harman radios is 2.120.
Originally Posted by Noxian
You would be quite wrong, Chrysler has out of date software on the Bluetooth uconnect modules they are putting in even the new 2012s, your symptoms indicate that.
I bet you if you hit the lock button on your iphone while its playing music the problem goes away.
Old May 17, 2012 | 06:53 PM
xsdbs's Avatar
what radio do you have? I would guess the 730 series radios, because my iPhone 4 & 4S both play fine with my 430N (Mitsubishi radio).
Originally Posted by 43jeeper
I was initially surprised and happy to find that the uconnect feature would automatically play my music files from my iphone without that annoying 3.5 aux cable, and it worked fine for a few weeks after I picked up my new 2012 Sport. But lately it plays them at 2x or 3x speed. ANyone else experience this? Ive gone thru the menu settings and cant seem to find anything that would be capable of adjusting that, and the iphone plays normally by itself and through my BT headset when at home. Its just in the jeep that it speeds the songs up.
The upshot is that Im listening to 3 times as much music as the rest of the world, so that at the end of hte day, I have like an hour more leisure time than the rest of you.
Old May 18, 2012 | 01:52 AM
5.56x45mm's Avatar
My u connect did this with my iphone as well (2011). What I found out by trial and error is that if the iphone screen is lit up, the music does the fast forward sound. So I just black out the iphone screen with the top button. Seems to work correctly when I do that for some stupid reason.
Old May 18, 2012 | 02:20 AM
Slob's Avatar
Have you tried going faster? maybe its a sign you need to be going faster?
Old May 18, 2012 | 05:21 AM
xsdbs's Avatar
The Uconnect SW update will actually cure the issue. The TSB # is 08-019-12 and this is a revised TSB from the one that was out last year. TSB# 08-036-11, the only difference is in some of the wording, there is no difference in the SW section.
