Brake fluid leak.
Hi all new to the board ..
2010 unlimited rubicon. I need to know the torq spec for the banjo bolts
on the front calipers front left was leaking today bolt is kind of loose and i dont want to go to the dealer for it thanks......
Bob
Bob
I'd say as tight as you can get it by hand then about 30*degrees. Just a estimation, I hardly torque anything unless it's a vital component. Just what happens when you do it for a living, get that "calibrated elbow" lol.
Make sure you have sealing rings on both sides of the fitting as well.
Truthfully, I wouldn't do anything with it. We pay good money for these things, let the stealership deal with it. Chances are if you play with the brake lines and can't get it to stop you are going to be footing the bill.
But I'm just a little anal and I torque almost everything. I'm also a weakie so hand tight for me may not keep anything on.
