Brake Squeal
Old May 31, 2007 | 08:13 AM
fattygio's Avatar
Default Brake Squeal
Slight brake squeal while applying brakes, usually after driving for a bit (heat??), should I be worried or is it normal..
9000km....
Thx
Old May 31, 2007 | 08:51 AM
IGOFSHN's Avatar
Brake squeal is usally caused from pads vibrating. It can also be caused by brake residue on the pads. If they squeak all the time then it is a problem, if it is occasionally then it is probably caused from brake residue and can be cleaned by rinsing with water.
Old May 31, 2007 | 01:15 PM
fattygio's Avatar
its not all the time....
