Broken bushing(pitman arm-draglink)
Old May 26, 2009 | 06:46 PM
shawndabo's Avatar
Default Broken bushing(pitman arm-draglink) w/ pics now
Anyone know where I can get a replacement bushing that goes in between the drag link and the pitman arm? Mine has a large rip in it causing a loud clunking noise on bumps. Pic 1 shows the passenger side drag link, pic 2-3 show the rubber part at the pitman arm and drag link. The clunking noise is coming from one of those two areas as the drag link can be turned slightly back and forth.
Old May 26, 2009 | 08:04 PM
RedneckJeep's Avatar
It sounds like you're talking about the rubber dust boot for that joint. If it's clunking, the damage is done. Replacing the rubber boot will do nothing. If it's what I think you're talking about, all it does is keep dust and rirt out of that joint.
Old May 26, 2009 | 08:14 PM
Hellbound13's Avatar
Just replace the part. Here it is..
http://www.moparpartsamerica.com/par...layCatalogid=0
Old May 26, 2009 | 08:36 PM
eDiveBuddy's Avatar
Go to Carquest or any auto parts store and pick up a drag lin/ tie rod end boot. I don't remember what size to get.
Old May 26, 2009 | 08:41 PM
Both of you seem to have missed the part where he says it's clunking. Replacing the boot ain't gonna fix a clunk.
Old May 26, 2009 | 09:09 PM
eDiveBuddy's Avatar
Naw hellbound posted a link to the TRE. I guess the clank did not register to me because if you actually take the boot off the TRE will clank against the pitman arm. But should not clank if it's only torn as the OP said. So I missed what he said. Heck I think all I read of your statement was all it does is keep dust out. Maybe it's time to go to bed.
Old May 27, 2009 | 05:31 AM
shawndabo's Avatar
I added pics to the original post. If anyone could help it would be appreciated.
Old May 27, 2009 | 06:50 AM
Yup. That's just the rubber dust boot. IF that's the joint where it's clunking and has loose play, the link needs to be replaced. Now, it's normal to be able to grab the link and "twist" it, but no side to side motion is normal at all.
Old May 27, 2009 | 07:17 AM
shawndabo's Avatar
Ok it will twist a little and there is no side to side motion. It sounds like metal on metal when I twist the link.
Old May 27, 2009 | 07:28 AM
Offroadme's Avatar
time for a new one
