Broken water pump bolt
So I was replacing the water pump on my 08 JKU when the bolt head snapped off. Ive soaked it w pb blaster and tried using some vice grips to try and loosen it with no luck. Any suggestions?
https://cimg8.ibsrv.net/gimg/www.jk-...611f4f5bf0.jpg Water pump bolt snapped |
Originally Posted by A. Favela
(Post 4334520)
Yep, heat is your friend with aluminum parts and steel bolts -- Aluminum expands about twice as much as steel when heated, so it tends to loosen. :cheers:
I'm curious as to what type of torch works for this. I have one of the standard hand held propane torches, Would that work or would I need something that generates more heat?
