Bumps on hood.
Bumps on hood.
I'm talking about those big rubber nipples that cushion the windshield when it's folded down. Since it's such a hassle to do so, I'd like to replace them with something flat and waterproof. I was giving the Jeep it's quarterly bath the other day and one of them came loose. I don't want to lose them, so I thought about replacing them. Any ideas?
While I don't think the idea was well received by many I recall a post where somebody did fine some flat plastic pieces that they put in place of the rubber stops. Not sure what to search on but it might be worth some searching.
Edit: check down in this thread for ktnr's hood w/o ... I was bored ... https://www.jk-forum.com/forums/stock-jk-tech-12/what%60s-meaning-these-2-rubber-fronthood-bumps-22691/
Leave them out. The holes will provide extra venting and will reduce hood lift and wiggle.... of course you know I'm joking ...... I like nipples.... er hood nipples.
extra venting! hah... the holes are like 1/4 inch.... I've thought about lights there also... just need some washers, it shoud be plenty strong. Although ya probably would have to drill larger holes for the light bolts....
I have seen mounts for a high lift jack that install in those holes. I am just afraid to lift my high lift across my hood. I know I will drop it and screw up my hood.
