Can i replace front axleshaft ujoint with aftermarket?
I ask because I see there are no retaining clips on the stock front axle shaft ujoints and need to know if these need stock joints. I've replaced a ujoint on my aftermarket driveshaft with clips which was easy need to know if these just press in and out if I get new OE ones. Sorry for the dumb question but I learn as I go. Thanx to this forum I've installed my 3.5 " lift without any experience and a ton of other stuff as well including my ball joints.
The retaining clips for the axle u-joints are on the inside of yoke. If you look closely at the center, by the cross you should be able to see the circlips (half circle around the cap) that holds the cap in the yoke.
