Changing diff fluid, do I need LSD additive?
Old Oct 20, 2009 | 07:00 AM
  #41
Mark Doiron's Avatar
Originally Posted by mudmagnet63
I think I will add the modifiers in the mobil 1. If a jeep isn't used in Extreme conditions what is?
While we are on the subject do most of you use RTV silicone to seal the diff back up or go with a gasket and silicone? The last time I used RTV alone I had a small drip, on the following fluid change I used a gasket with a small amount of RTV and no leak
LSDs require a certain amount of friction--not too much and not too little. Mobil 1, which I've used, works fine in a Jeep that is wheeled--without adding any modifier.
I use LubeLockers on my Riddler diffy covers.
Old Oct 20, 2009 | 07:06 AM
  #42
mudmagnet63's Avatar
Lubelockers are the rubber type gaskets that can be reused ? I saw them for sale at Northridge I think.
Old Oct 20, 2009 | 07:25 AM
  #43
SlyStevie's Avatar
Adding LSD to anything makes for a great story the next day...
Old Oct 20, 2009 | 07:27 AM
  #44
Oh how true
Old Oct 20, 2009 | 07:32 AM
  #45
fish's Avatar
From: Apple Valley, California Good ole Mojave Desert.
i just ran royal purple when i had my X with LSD and experienced no noise or any problems wheeling or otherwise. hope that helps.
Old Oct 20, 2009 | 09:54 AM
  #46
Adam3612's Avatar
I used Valvoline SynPower 75/90 when I cleaned out the diffs a couple of months ago. I called Valvoline to make sure I didnt need to add any modifier and the tech guy told me there was already a certain percentage in it. Most of the big brand name synthetics like Mobil 1, Valvoline, Pennzoil etc already have the modifier in it, just call and verify with them for peace of mind. Don't add anymore if their is modifier in the oil already, you risk running an open diff and your LSD will be useless.
Old Oct 20, 2009 | 10:34 AM
  #47
Yes. I recommend them because they are much better than futzing about with a scraper and RTV.
Old Sep 22, 2010 | 10:48 AM
  #48
MagnumD69's Avatar
Default OK, so how long are the factory LSD supposed to last?
How do you know it is wearing out? Or already gone?
Is it replacable?
