Changing fluids
Old Dec 22, 2009 | 07:58 AM
jdredrock's Avatar
Exclamation Changing fluids
I want to change the diff, transfer case, trans and oil myself coming up soon, maybe soon after the 1st of the year. I was wondering what everyone suggests as far as weight, brand, and so on. I have an 2dr X with stock D30/D44, lifted 3" and 33" tires.
Old Dec 22, 2009 | 08:03 AM
Biggy's Avatar
I changed mine all over to Amsoil. No problems so far. Do a search there's lots of info on the subject
Old Dec 22, 2009 | 08:18 AM
NorthRiver's Avatar
The fluids in my 2010 JK are the same thing that are used in my '07 Ram 3500.
I use Mobil 1 or Royal Purple in the diffs. Generally there is M1 in one diff and RP in the other. None of the local parts stores ever have enough of one to do both diffs with the same fluid.
The transfer case and trans get ATF+4. The ATF+4 is pretty much all the same so I generally use the Mopar branded stuff at Walmart. I've also used Valvolines version.
I just did the first oil change in the JK at 1000 miles. I used Pennzoil 5w-20. At 5000 miles I'm switching to Mobil 1 5w-20.
Old Dec 22, 2009 | 09:12 AM
if you redline the engine alot i suggest going to 5w30 and nothing but synthetic. i bump up the rear diff the the 74w140 they suggest for towing as well. allways synthetic
Old Dec 22, 2009 | 09:48 AM
NorthRiver's Avatar
Why the suggestion for 5w-30?
Old Dec 23, 2009 | 10:18 AM
jkwade's Avatar
I just did the diffs and oil change. No big issues, but don't worry about some sludge on the diff drain plug. I was worried, opened the cover up, and it was perfectly clean inside.
I used AMSOIL in the diffs and engine. I plan on extending my drain intervals on the engine oil, not the differentials since I'm likely to be in water frequently enough.
