check engine light choke came on
Old Nov 3, 2009 | 10:05 PM
cone99's Avatar
Default check engine light choke came on
choke light came tonight and kept staying underpowered, i had to nurse her home. it was a street ride back home, then 20 mins later ran fine. has anyone had this happen to them before??? first time ever for me and she's an 08 rubi.
Old Nov 4, 2009 | 06:51 AM
ronjenx's Avatar
I don't know of any "choke" light on the JK. Are you referring to the Electronic Throttle Control light?
That will illuminate if the throttle plate becomes stuck, and the JK will go into "limp home" mode, restricting rpm and speed.
If the throttle unsticks, everything will return to normal.
Check for remaining codes P2072, P2110, P2118.
P2072 is for an ice-frozen throttle plate. Don't laugh. It can happen above freezing ambient temperatures. (I've had it happen in a Cessna 170 when the ambient temp was in the 70's F.) Anyway, if the plate is stuck, the computer may assume it is for ice.
P2110 is for ELECTRONIC THROTTLE CONTROL - FORCED LIMITED RPM
P2118 is for ELECTRONIC THROTTLE CONTROL MOTOR CIRCUIT
These are just a few conditions that will turn on the light and create a limp home mode.
Look for codes and post any you find.
Old Nov 6, 2009 | 04:15 PM
cone99's Avatar
thans, i'll run a check this weekend and post what i see.
Old Nov 7, 2009 | 04:57 AM
JKinNNY's Avatar
Had this happen earlier this year on my drive home from work. Did it clear up when you started it back up? If so, same problem I had....clogged PCV. Stealership replaced it under warranty, and no more problems.
Old Nov 7, 2009 | 05:11 AM
ronjenx's Avatar
Your throttle control light came on, and the Jeep went into limp-home mode?
