check engine light help
Old May 15, 2010 | 10:15 AM
Bosox5's Avatar
Veteran: Coast Guard
Default check engine light help
Hey all, I got a check engine light after changing out fluids in my auto tranny and diffs...I am trying to figure out what DTC with the writeup but for some reason its not working! Any tips to what I am doing wrong?
Old May 15, 2010 | 07:02 PM
RA032726's Avatar
Banned Member
First few times I tried to check for codes it did not work until I figured out I was not keeping the key pushed in while turning it off to on and back to off. Keep light pressure on the key pushing it to the center of the steering column. If you are doing it right you really don't feel the intermediate ACC position. Once you start a 3 turn sequence don't pause at the on or off position and don't let the engine crank. Hope this answers what you were asking. Good luck.
Old May 15, 2010 | 07:15 PM
Bosox5's Avatar
I did figure this out, I was doing it right just not doing it fast enough....speed is key!
