Check you tranny fluid!
Old Jan 25, 2011 | 05:23 PM
Jiblet's Avatar
Originally Posted by OoPEZoO
Guys.....he has a 6-speed manual. ....
MY BAD!!!
I should have seen his sig.....
thanks for the catch, OoPEZoO.
Carry on.
Old Jan 25, 2011 | 06:47 PM
chknkatsu's Avatar
the capacity is 2qt but arent you supposed to put less because of heat expansion?
Old Jan 25, 2011 | 06:50 PM
rinkishJK's Avatar
Used gear oil always smells bad, its just to what degree does it stink. OK gear oil stinks up your garage for a day, while bad gear oil smells like burnt toast and lingers for 4-5 days.
I had the final drive on my motorcycle crap out on me a few years ago that resulted in burnt gear oil. The smell was so bad that my wife just about puked when she walked into the garage, and the smell lingered for a week. The final drive only holds about 1/2 a quart.
I have read lots of good opinions on the Royal Purple Syncromesh, but have never run it in anything. I have always been a big fan of Red Line MTL. I also need to drop the oil in my JK tranny, but haven't decided what I wasnt to put back in yet. Whatever they put in from the factory makes it shift like complete shit when its cold out. When it drops below ~25 degrees, each shift takes a good 3 seconds to keep anything from grinding. After a mile or so, everything warms up and shifts fine. The Redline MTL did wonders for the manual BMW's I've had in the past that had the same issue, so I might go that route........BUT, I do have the lifetime powertrain warranty so that might scare me into refilling with whatever Chrysler put in there in the first place.
Amsoil is the same color as factory fill. I use it and it works great. Used rp also before but I think I prefer amsoil.
Old Jan 26, 2011 | 02:50 AM
im-ocd's Avatar
Originally Posted by Ryanc
Drained my tranny fluid, looked pretty low from my estimation, no metal chunks, a little bit of metal fiber was present on the magnet. Fluid was nasty brown. Capacity is about 2 qts, looks like there was only 1-1.5 qt in there.
Only 20 thousand, but I have owned it for 3 years.
Note to self, check and likely drain manual transmission fluid at 15,000 miles.
Old Jan 26, 2011 | 03:39 AM
toymaster's Avatar
Guys.....he has a 6-speed manual. His fluid was never red. It should be brown due to it being a gear oil, not ATF......
Actually it is Manual transmission Lubricant and not normal gear oil. Also, ATF goes in the transfercase. (Side note many manual trans take ATF, just not this one.)
Either way, it depends what the OP means by "nasty brown". To me, IMO, that would be a descriptor of something unusual not a normal color for a lubricating fluid; as I'm sure the OP knows what that looks like.
Old Jan 26, 2011 | 06:16 AM
largo's Avatar
I ran Royal Purple in my 09 6-speed and it did help with the shifting issue I had. It is pricey, but you cannot put a value on something like tranny fluid.
Old Jan 26, 2011 | 09:49 AM
A/C Guy's Avatar
Originally Posted by Flip94ta
Are you guys fans of Royal Purple in the manual case?
Pennzoil has a full synthetic gear oil for Jeeps, called Synchromesh. Autozone and Checker/ O'Reilly carry it. I only buy lubricants that specifically mention that they exceed GM, Chrysler, Ford, Jeep, etc requirements.
Old Jan 26, 2011 | 12:24 PM
hetkind's Avatar
The JK six speeds use GL-5 gear oil...I stock the 80w90 stuff that I usually buy in the five gallon bucket and put a pump on top:-)
The reason gear lube smells is from the high sulfer content...you can buy and use the botique brands, but I am not sure what it will get you.
On the other hand, the six speed in my Dodge Ram, also made by Gertag, requires ATF, but gear lube also works.
Now, does the transmission use an oddball metric allen to access the fill plug?
Howard
Old Jan 27, 2011 | 04:37 AM
OoPEZoO's Avatar
The biggest advantage to a few of the higher end Manual Transmission Lubes is the cold weather performance. And I mean COLD weather performance. Down to about 25-30 degrees everything is usually fine, but anything lower than that gets real clunky for the first few miles.
I have no first hand experience with the JK yet because I have yet to swap out the transmission oil, but I do have quite an extensive amount of experience on BMW manual transmissions (also made by Getrag). On a 5 degree morning, my BMW's were so hard to shift that it felt like I was going to break something getting it out of gear, and almost always would grind a little when putting it in the next gear. My JK acts the exact same way. Once I dropped the factory tranny oil and went to the Redline MTL, I could shift it with my pinky finger in whatever temperature I wanted with no grinding at all. In fact, every single interaction with the gear shift was improved. The BMW I just sold to my nephew had over 245k miles on it with 6-7 hard race track days on it, and still has the original transmission in it. That made me a believer in good quality after market gear oils.
Old Jan 27, 2011 | 08:23 AM
Ryanc's Avatar
I should clarify, I was being a little dramatic in my op. The fluid was darker than I expected and appeared to be lower in volume than I expected.
