Clutch not slipping but seems to be engaging very high
As your clutch wears will it start engaging higher and higher? I have 96, 000 miles on my 07 JK and just wondering if my clutch is getting close to the end. I cant remember what my clutch felt like when it was new. Also, if anyone had their clutch done on their Jeep (07 and up) what did it end up costing? Is there a stronger gripping aftermarket clutch. Any answers out there? Cheers everyone!
I never really paid attention when I got it (I was the 1st owner) But it starts grabbing almost all the way up. It grabs good, but Im beginning to wonder... Just seems kinda high
Have you pulled your slave cylinder to see if its leaking?
Have you done any recent work in the break or clutch system that could possibly
lead to air getting in the line?
Just trying to think of things to check/rule out.
Originally Posted by JKred
Mine starts to grab at 1/4 release, and doesn't fully hold until 3/4... There is a lot of contact throw
In the case of a traditional cable-operated clutch, in a word: yes.
However with the "self adjusting" hydraulic set up found on the JK, they engage pretty high even when new. Personally, I would much rather if my JK had a cable clutch; I find the hydraulic one very vague & lacking any real feel, & miss being able to adjust it to my likeing as it wears as you can do with a cable one. Plus, with a cable-actuated clutch all that can really go wrong is the cable can brake, which is a cheap & easy repair; between the master cylinder, slave cylinder, and hydraulic lines there is far more to go wrong with the JK's hydraulic set-up and we all know how prone to premature failure the slave cylinder is.
A way you can test how much life is left is to firstly engage it on level ground and then see how much more pedal travel is required to engage it fully (in 2WD) on a steep hill or an with the front wheels on an obstacle like a kerb or small log or something; if you have to let it out a lot more then it could be a sign you clutch is on the way out.
