Clutch question
Old Apr 27, 2013 | 08:27 PM
zero_traction69's Avatar
Default Clutch question
How do I know if my clutch is going? And what is a good aftermarket clutch? And how hard is it to change a clutch!
Old Apr 27, 2013 | 08:29 PM
CDN-JK's Avatar
Best way to check is to drive into a water hole thats headlight deep and push your clutch repeatedly!!
lol jk Blackhole...... you will know when its burnt.....check out centerforce.
Old Apr 27, 2013 | 08:41 PM
Thanks ice breaker!!!! It doesn't feel bad but it been slipping a little. It just feels weird, I think I fucked it when I got stuck in the icey pond lmao it just sucked in so much water
Old Apr 27, 2013 | 08:47 PM
OC-JK's Avatar
I run centerforce and it works well for me.
Old Apr 27, 2013 | 08:48 PM
CDN-JK's Avatar
I know dude. Mine too. I made ONE slip up where i got in, and just out of habit pressed it in to start it when i didnt mean to. I can feel it slipping going from stopped into 1st gear.
Check out this install thread. I would want at least a week off work for this one... Install
Old Apr 27, 2013 | 08:53 PM
Yeah that's a super write up, I am just debating on doing it now and call it a day or risk it going out completely on the trail I have 47k on the oem clutch. And I would probably go with a center force as well. I just need time off work to do it. I will probably try and get it done at my shop at work
Old Apr 27, 2013 | 08:55 PM
CDN-JK's Avatar
Yeah that's a super write up, I am just debating or not to do it now and call it a day or risk it going out completely on the trail I have 47k on the oem clutch. And I would probably go with a center force as well. I just need time off work to do it.
I think it would be one of those mods where we both were gonna do it and i drove down to your place and did 2 at once. Just for the extra set of hands.
Old Apr 27, 2013 | 09:08 PM
Sounds like a plan to me! We have the technology we can fix broken jeep stuff
Old Apr 28, 2013 | 05:12 AM
genesbro's Avatar
Best way to see if it is slipping is to be going very slow and have it in 4th gear and hit the gas hard. If the rpms go up and the speed doesn't change then it is slipping.
If you can use a lift it isn't very hard to change. Be sure to change the pilot bearing also and all will be good.
Old Apr 28, 2013 | 07:41 AM
Cool thanks man. I will try and see if it's slipping
