Code 2181
Old Feb 27, 2012 | 03:41 PM
Greenhornet's Avatar
Default Code 2181
Hi all had a check engine light come on today, got the code P2181 which is for coolant I checked the reserver tank it shows between min and max at hot temperture, My question is should it be hot or cold for the min and max lines be used?
Old Feb 27, 2012 | 04:02 PM
OH9JK's Avatar
JK-Forum Ambassador
P2181-COOLING SYSTEM PERFORMANCE
When Monitored:
Ignition on, Engine running, and no ECT DTCs present.
Set Condition:
PCM recognizes that the ECT has failed its self coherence test. The coolant temp should only change at a certain rate, if this rate is too slow or too fast this fault will set. Two trip fault. Three good trips to clear MIL. The MIL and ETC light will illuminate.
Possible Causes:
LOW COOLANT LEVEL
ECT SIGNAL CIRCUIT SHORTED TO VOLTAGE
ECT SIGNAL CIRCUIT OPEN
SENSOR GROUND CIRCUIT OPEN
ECT SIGNAL CIRCUIT SHORTED TO GROUND
ECT SIGNAL CIRCUIT SHORTED TO THE (K900) SENSOR GROUND CIRCUIT
THERMOSTAT
ECT SENSOR
POWERTRAIN CONTROL MODULE (PCM)
Old Feb 27, 2012 | 04:12 PM
Default thanks
Thanks for that info.
Bill
Old Feb 27, 2012 | 04:20 PM
Stillmotion's Avatar
I actually just posted the same issue. Let me k ow what you find out. I got this code today.
Old Feb 27, 2012 | 04:47 PM
ronjenx's Avatar
His solution may not help you, as you are getting quite a few other codes, some unrelated, at the same time.
Old Feb 27, 2012 | 09:44 PM
jk-tony's Avatar
9 times out of ten a thermostat will fix this problem.
Old Mar 3, 2012 | 09:43 AM
Default nothing
Well I cleared out the code and it has not happened again, not sure what caused it.
Old Mar 3, 2012 | 01:06 PM
jk-tony's Avatar
Thermostat codes will usually show back up in a couple days. Hope it stays off for you though.
Old Mar 3, 2012 | 04:27 PM
mechano's Avatar
mostlikely a t-stat prob. rarely an ect issue.
If I were in your shoes I would also be makin sure I replace the t-stat with an OEM t-stat. JMO.
