Code reading
Old Jun 21, 2009 | 01:48 PM
berg's Avatar
Default Code reading
Is there any way to read fault codes without a code reader?
Is there any way to erase them and turn off the Check Engine light without a reader?
Old Jun 21, 2009 | 02:41 PM
wrnglrguy's Avatar
Do as stated above, but just don't actually start the engine when doing it. Turn it to the on position right before it cranks.
Old Jun 21, 2009 | 03:55 PM
Vernnz's Avatar
You will need a programmer to clear any codes. Either that or fix what is actually wrong.
Old Jun 21, 2009 | 04:01 PM
JK Wes's Avatar
do that then if it tells you any code write it down and just search: jeep jk dtc codes...then u'll know what they mean
Old Jun 21, 2009 | 04:48 PM
JKMARINE's Avatar
Solid info. I agree 100%.
Old Jun 21, 2009 | 05:14 PM
Vernnz's Avatar
www.project-JK.com
Click on Jeep JK Write-Ups.
Under Troubleshooting is Diagnostic Trouble Codes - DTC How to Check Them & What They Mean
Old Jun 22, 2009 | 06:46 PM
berg's Avatar
Thanks for the replies.
For some reason the check engine light went out today.
I must have that secret "auto fix" option
Old Jul 23, 2009 | 11:34 AM
JK-Blue's Avatar
I go to the drive-in frequently and after sitting with the key in accessory to play the radio for several hours, when I start the jeep the check engine light and lightning bolt come on and the engine runs rough. If I turn the ignition off, then restart, the engine runs OK but the check engine light stays on. After a day or two the light goes off. the only code indicates an issue with the cooling system.
If after sitting with the radio on for several hours I first turn the key to off, then start the engine I get no lights and everything runs fine.
Old Jul 27, 2009 | 11:26 PM
iannis's Avatar
If you fix the problem the code will remain registered and the check engine light will remain lit.
However if you disconnect the battery for 2 minutes and reconnect it the check engine will go off and the code will clear, provided the problem is resolved.
