Cold air from dash area
Old Nov 5, 2010 | 06:47 AM
firecapt's Avatar
Default Cold air from dash area
During cold days, I have cold air that comes form under the dash, like just below the steering wheel. It blows just onto my knees. I can't seem to locate an opening. Anyone else have this issue? or any solutions?
Old Nov 5, 2010 | 07:35 AM
tcodtj's Avatar
I had the same problem. I finally found a hole looked like it would be where the clutch cylinder would mount for a manual trasnmission. My guess is that it should
have had a plug in it from the factory for an automatic.
Old Nov 5, 2010 | 08:05 AM
KJJK's Avatar
Same thing here. When its cold I have to have the heater fan on high all the time just to overpower the cold air coming into the cabin. tcodtj where can I find this hole?
Old Nov 5, 2010 | 08:18 AM
lvnlife86's Avatar
If you look up under the dash to the left you should see a black rubber hole, its either an access point or just a random piece of rubber that chrysler put there...I used it to runn the power source for my after market sub and amp. Make sure there's not a cut in it or has been completely removed. If you guys can't find it ill get a pics of it if you'd like. Another way is to open the hood and look down into the far right side on the fire wall and you should see it. It just looks like a big 2" rubber plug. Hope this helps
Old Nov 5, 2010 | 11:03 AM
tcodtj's Avatar
Thats the place alright. But mine didn't have a plug just an open hole.
Old Nov 5, 2010 | 11:09 AM
lvnlife86's Avatar
Yea until you have time or it gets warm out, id just plug it with a rag or some duct dape
