Cold weather sounds.
When the temp dips some of the sounds are nasty. The first time starting after sitting out in sub freezing and a wicked chainsaw buzz sounds for a second. When I get rolling a whine from what seems like the axle (Still there when rolling in neutral) and then the heater fan squeaks when it's on low and it's cold. It all disappears when warmed up. Anyone? Anything can be done? Just don't worry? I'm at about 25,000 miles. Thanks.
The chain saw buzz at startup is the starter not disengaging quickly enough when cold. Mine did it first the first time when it hit -30*F. when it warmed up to -10*F, it didn't do it anymore.
The heater fan squeak when cold means the motor needs to be lubed.
Don't know what the axle sound is you describe.
This would be my first winter with the carpets out (worthless top/half door seals), and I too notice a sound coming from the front axle sort of like a whirring. Its independent from the motor and seems to be coming from the middle just a little in front of the dash. Also only happens when temperature has dropped below freezing.
I have noticed some oil spots (very small) underneath the Jeep and question whether the seal around the diff is failing, and a loss of lubricant coupled with the cold weather is causing such sounds.
I have not had a JK fan out. On other vehicles, removing the fan from the firewall allowed the motor to be lubed. I'll look into the service manual if you want. It should be covered under warranty, though, if you can get it to squeak at the dealership.
edit to add:
REMOVAL
NOTE: The blower motor is located on the bottom of the passenger side of the HVAC housing. The blower motor can be removed from the vehicle without having to remove the HVAC housing.
1. Disconnect and isolate the negative battery cable.
2. From underneath the instrument panel, disconnect the instrument panel wire harness connector (3) from the blower motor (4).
3. Remove the three screws (2) that secure the blower motor to the bottom of the HVAC housing (1) and remove the blower motor.
It looks easy to get at, but I don't know if the motor bearings can be lubed.
edit to add:
REMOVAL
I had the same initial "buzz" recently in some really cold weather. I started doing something different, I now turn the key to the on position for 2-3 seconds, and then crank and have not had the sound since. I can't verify that it has actually changed anything, but will continue to do it in cold temps until it proves otherwise.
1 Post
power steering will make noise on start up, when it is -20*c
when it is that cold one should be a little gentler with things, throttle input, speeds, at least until the needle comes off the cold pin.
I noticed same buzz saw noise this AM.
0F windy out and jeep was outside all night at work.
I'll have to try the 2-3 sec delay and see what that does.
Almost sounds like same idea as glowplug warmup on a deisel, something has to get "warmed up/woken up" before starting.
And I second the go easy till the needle gets off the cold side for a bit.
Ronjenx, thanks for looking that up. I have mine going in tomorrow for the fuel splash problem (new filler tube) I'll ask them to leave it out overnight and listen for it. (Supposed to be low teens in temp). If they won't listen, I'll do the work. Don't want them ripping up my Jeep and causing more noises.
