Contaminated brake fluid
Old Mar 10, 2017 | 04:27 PM
OverKill's Avatar
Vet Army
Does the power steering take ATF + 4?
Old Mar 10, 2017 | 04:49 PM
ronjenx's Avatar
...Yes...
Old Mar 11, 2017 | 08:10 AM
auradeus's Avatar
Originally Posted by ronjenx
While you are waiting, put some of each fluid in a clear cup and see if it will actually separate into layers.
It did settle, actually within a couple hours, into two perfectly discernible layers, fortunately with the power steering fluid on top. Sucked out the top layer again this morning, put new brake fluid in. Dropping off to the dealer today for a flush next week. Thanks again for your help.
Old Mar 11, 2017 | 08:27 AM
ronjenx's Avatar
That's good to know. Thanks.
Old Mar 11, 2017 | 02:59 PM
zstairlessone's Avatar
Ask your dealer if they vacuum bleed/fill the brake system. If they do then they will most likely completely drain and flush the system, if they don't they will probably just fill and bleed the system which isn't what you want.
