Coolant Fluid?
Old Feb 15, 2013 | 02:08 PM
  #21
calemasters's Avatar
Originally Posted by PiratesFan
A couple of months ago my radiator cap was leaking i changed it and haven't notices any more fluid coming from anywhere but I've put about 1,000 miles since I've last checked my fluids checked today and my coolant level has dropped some more it was just below the halfway mark between max and min now its about to the min.... What could be causing me to loose fluid there is never any drops on the the ground and my driveway is concrete i would see it easy... I've crawled underneath and see no sign of fluid anywhere.... Even when my cap was leaking a bit there would be no fluid on ground but evidence of it dripping on frame and parts... Any help?
You could have had some air in the system from the defective radiator cap. Maybe you did not loose any coolant, just some air bleed out of the block/heads and the coolant replaced the volume of air that was purged.
