Coolant question!
Old Jul 10, 2011 | 10:22 AM
black-x's Avatar
Default Coolant question!
My coolant resevoir is now at the minimun mark. This is the lowest it has been since i bought the jeep back in 07. Usually, the dealership tops it off when I get my oil changes but I don't have one scheduled anytime soon. My question is, should I just pick up some Prestone from the store and fill it back up? No mixing with water needed? I just find it kind of weird that in the four years of ownership I haven't had to do this even during the hot summers of Fl.
Old Jul 10, 2011 | 01:08 PM
mkjeep's Avatar
Go to the grocery store and get a gal of distilled water for a dollar and fill the res back up.
Watch it for dropping level, you could have a leak, or leaky rad cap.
Old Jul 10, 2011 | 01:47 PM
Mark Doiron's Avatar
Other random thoughts ...
1. Coolant can blow out the tailpipe with a blown head gasket or cracked block.
2. If you off-road keep your coolant level near that min mark. Otherwise when you go up/down steep terrain you'll spill some out the overflow.
3. You must use Chrysler-compatible coolant or you risk system corrosion. Seriously--get the stuff specified in your owners manual.
Old Jul 11, 2011 | 02:12 AM
JKlad's Avatar
Yeah, as MK said you may have a leak, particularly as you've never noticed much of a drop previously. Since it's an '07 you may be due for a new waterpump as these are known to start leaking after a few years.
