Cruise Control
Old May 15, 2014 | 08:29 PM
KenB1010's Avatar
Default Cruise Control
My cruise control hasn't been working since I broke the wires to the wheel speed sensor. I replaced the sensor and repaired the wires, but still no cruise control.
I cleared the ABS sensor codes and have driven about 200 miles without a code. Still no cruise control.
Anyone have any ideas?
Old May 16, 2014 | 01:36 AM
Hogghead's Avatar
Unhook the battery for at least a half hour and do a system reset.
Old May 16, 2014 | 02:45 AM
OH9JK's Avatar
JK-Forum Ambassador
A few thoughts....
Does the cruise control indicator light up on the dash when you press the button?
Are any of the ABS/ESP/BAS lights on?
Does your horn work?
Check fuse M37.
Steering wheel must be centered.
Old May 16, 2014 | 04:01 AM
rob_engineer's Avatar
Not sure if our JKs have this, but I had a mercury mountaineer with faulty cruise. I finally discovered that there was a sensor on the master cylinder that told the cruise to shut off when you tapped the brakes. That sensor was bad so I replaced it for about $15. That fixed the problem. Apparently my cruise was thinking my brakes were applied because the sensor was bad.
Old May 16, 2014 | 06:09 AM
OscarTheJeep's Avatar
I just installed cruise on our '09. With the drive by wire setup, the cruise control is completely software based. There's only a few things that could be causing your problem.. The stalk is faulty or the computer software has become corrupt.
I don't think the wheel speed sensor or wires have anything to do with it as long as the lights are out on the dash.
Old May 16, 2014 | 06:27 AM
metaldemon's Avatar
Mine was the switch on the steering wheel.
