Dash grocery bag hook replacement
Old Sep 30, 2019 | 09:24 AM
mpd2434's Avatar
Default Dash grocery bag hook replacement
Has anyone figured out a way to replace that grocery bag hook on the right side of the dash below the climate controls? I would like to use this for an aftermarket USB port to wire right into my Pioneer for Android Auto but the whole is huge. I measured it to be about an inch and 3/4
Old Sep 30, 2019 | 10:14 AM
resharp001's Avatar
Loved
Community Favorite
What the heck are you even talking about? I have a grocery bag hook?
Old Sep 30, 2019 | 10:39 AM
karls10jk's Avatar
Yep, I've seen it done somewhere on the forum. On the upper models, I think it's a mirror adjuster knob. I'd look for the factory parts and try that route.
Old Sep 30, 2019 | 10:44 AM
resharp001's Avatar
Loved
Community Favorite
On the upper models, I think it's a mirror adjuster knob..
Had to look it up to see what the heck this was. Y, on the '12+ this turned in to a 12v outlet. Mirror adjuster knob on the corresponding left side. That's kind of weird. Seems like a silly thing and that a 12v would have made more sense from the start in '07.
***well, I just dug further and I see this on '15s even. Maybe that 12v came as part of a package. The only packages on my '13 were uconnect (in order to get the electric windows) and max tow.
Old Sep 30, 2019 | 02:03 PM
mpd2434's Avatar
Apparently this comes on the less optioned models like mine. The problem is the opening that the hook comes out of is alot larger than a 12v/lighter plug opening. I used a hole saw to cut some plastic trim rings the same size as the hook for the front and rear of the opening. Once my usb plug comes in I will measure it's diameter and cut the holes in the trim rings to mount it.
Old Sep 30, 2019 | 02:13 PM
Captain Skip's Avatar
I just did mine last week. I got this usb plug off of Amazon - aluminum USB double port
The USB port is slightly smaller than the opening for the grocery bag hook. I took my dremel tool and cut the hook off, smoothed the surface and drilled a hole in the center of what I had left to fit the USB port. Essentially I turned the grocery bag hook into a bezel for the USB port. Rather than tap into the cigarette lighter wiring I just ran a wire to the fuse box and put in an add a circuit fuse tap on a circuit that is only energized when the key is on/Jeep running.
Old Sep 30, 2019 | 02:26 PM
resharp001's Avatar
Loved
Community Favorite
I learned something new today folks. I always thought people putting USB chargers there was just to replace the factory 12v. This makes way more sense now.
Old Sep 30, 2019 | 02:45 PM
mpd2434's Avatar
That looks clean and exactly what I'm looking for. I may have to rethink making my own trim rings and do the same thing. Who would really use the grocery hook to attach a bag to it anyway?
Old Sep 30, 2019 | 03:15 PM
I actually drilled it out from the backside. It Made it easier finding the center of the bag hook.
Old Oct 2, 2019 | 04:24 PM
mpd2434's Avatar
That wasn't too bad. I made my own plastic trim rings/washers, painted them and installed a USB/HDMI combo plug since my Pioneer has both on the back. USB works great with Android Auto and charges my phone. Waiting on the HDMI to USB C cord to arrive to try out HDMI port. I also found another USB plug I purchased awhile ago and forgot about. I drilled into the side of the dash and installed that also. That one I plugged into the USB port on the radio that works with Apple Car play. I don't have an iPhone but it will still charge and Android and both look like there factory installed which is what I wanted.
