Dead at 34K
A guy I work with had this happen to his Nitro. Hydrolock is what the dealership said. They pulled the motor apart, and found antifreeze and water in the motor.
This whole process has taken 11 weeks so far, and they are heading to an arbitrator to get things sorted out.
Ensure that you have all of your documentation together. If you have a snorkel, and they find water in the engine, you may be on the hook for the engine.
All the best.
All the best.
I've been on the forums for quite a while, and have seen no real connection between engine problems, and assembly plant.
Most people don't know where their engines were built.
The engine number is on the left rear of the block, just below where the head/block parting line is. The second place in the engine number will be S for Saltillo, Mexico, or T for Trenton.
Here is where things stand so far:
#4 bearing has spun, and the piston made contact with a valve. No apparent damage to the cylinder wall or head. Fortunately, when it failed, I was going pretty easy down a gradual grade, dead idle, no load. And, it shut itself down right away. They are still in the process of tearing it down, so there could be some surprises still to come.
I have provided the dealer with all my maintenance records, but I have one gap where I did an oil change myself, so that could be an issue if someone wants to get really picky. The service manager thinks I will be ok, as I can show a pattern of proper maintenance. Also, there was no sludge present, no other unusual wear, and the Jeep is obviously quite well cared for.
I mentioned to him that I had done quite a bit of research on mechanical issues with JK's, and that it seemed there were a lot of reports of spun bearings on relatively low mileage '07s and '08s. He said that his experience would tend to confirm this, and he often worries because he owns an '08 on 38's.
I'm still holding my breath, but so far this has gone pretty well. The service manager has been very helpful and straightforward, and seems ready to go to bat for me.
Thanks for all the support, it's pretty cool!
All the best.
All the best.
Off topic, but which B.F.E Michigan? I grew up in Hart, went to Michigan Tech in Houghton, and lived in the Leelanau Peninsula for several years. Really miss the summers there, no where better on earth from May-Sept!
Sure, a thrown rod caused by a spun bearing can cause a piston on the upstroke to let go & make contact with the head, but will usually give plenty of prior warning (spun bearings generally result in very audible rod knock that gradually gets worse over time before the bearing finally fails & the con rod lets go). With the symptoms of the computer going nuts & lighting up the dash, and the fact that the piston made contact with a valve but caused no damage to the head or cylinder wall, sounds like something else besides a plain old spun bearing is going on here. Had a buddy with an old diesel Toyota Hi-Lux (Tacoma) that was suffering similar issues to what the OP has described and it turned out that the timing belt had jumped a tooth.
