Is the dealer service rep trying to squeeze me for money?
It should have been replaced with an oem pump in the first place unless you agreed to something different. The "flush" is BS. They're trying to get you to cover the labor.
It should have been replaced with an OEM pump... Unless you have an extended warranty. And being you drive an 07 Id assume it's a aftermarket (3rd party) extended warranty company, then the company will put on the cheapest option to save cost. Do you have an extended warranty or did Jeep extend the warranty on the P/S pumps for the 07's?
The flush I would assume they are recommending based off of mileage/time. Fluids (Especially oils) viscosity will break down over time and should be replaced even if the system is sealed. This is the main reason for them recommending the Flush.
