The Die-hard Platinum AGM best value replacement is here!
I got my AGM (duracell platinum) from sams' club for around 140ish if I recall correctly? Is in 34/78 configuration for dual terminal. Spent a couple of days checking around locally to find that to be the best value
-edit- That was more for others that find themselves to this thread as it seems you already found your replacement. For your situation, I have thought about changing my main terminals to side-post setup so I can use the beefier top posts for accessories, but I am still working on acquiring said accessories...
https://www.samsclub.com/p/duracell-...p_product_1_10
RednRoll - great explanation but perhaps I missed on my intent with my message. What I meant was not to say they might be the best but to say could be the best value. What I mean is that if the battery lasted only about 60% of the distance of the best one then you pay around $150 for the Costco one and $400odd for the good one then you are $$$$ ahead by going with the Costco unit if you don't mind replacing the unit more often. You certainly made a lot of research for something most of us take for granted. Our batteries seem to last quite a while up here in the freezing cold weather no matter the brand.
I agree with you that the Energizer is a pretty good value, but if I use a similar definition of "value" as you have, where higher specs are not a priority but the lower price has more priority and you look at my chart, I think an even better value than that Energizer, is the Duracell Platinum sold at Sam's Club. The Duracell Platinum is an East Penn battery Which I've seen at Sam's Club for $120USD with occasional sale specials for around $100USD. So comparing the Duracell Platinum AGM at Sam's to the Energizer Max, the Duracell has slightly higher specs than the Energizer while the price is significantly less as well.
Duracell Platinum(East Penn) vs. Energizer Max (Johnson Controls)
The best value in regards to top available performance vs. price is currently the PowerX2 AGM with the deals that can be found at BatteriesPlus.
Being able to easily identify both types of "value" was the intent of my chart.
I likely should have made my definition of "value" more clear in my OP.
The Duracell Platinum at Sams is the best value in regards to price for a group size 34 AGM, while disregarding the top available performance specs. That's actually the one I was going to purchase until I stumbled across the current deals going on at BatteriesPlus for the Northstar X2Power.
Although similar, Group size 27 has a larger volume than Group 34, thus more battery material can be put inside a Group 27 container. Here's the actual data I have in regards to volume capacity.
I also made a comment questioning his source of information because he had indicated that the DieHard "Gold" is an Enersys manufactured battery where my sources have all indicated the Gold series is made by East Penn instead but as we all know, the Die Hard "Platinum" was made by Enersys. Most of my research, I had gone to the store and grabbed the specs and read the fine print of who manufactured it and I do recall visiting Sears for the DH Gold series.
https://www.youtube.com/watch?v=h7rT...77396522199755
FYI, a set of these did the job for my secondary front post accessory connections.
https://www.amazon.com/dp/B0060YHLJ8...v_ov_lig_dp_it
They carry them at Meijer, was like $3.80 each.
