Dieseling/Ratteling sound coming from Engine/Transmission while under load...
Old May 31, 2012 | 09:19 AM
  #21
Synthetik's Avatar
My 2011 has been doing this for the last 10000 miles or so. Dealership won't acknowledge that its a problem.
Old Jun 1, 2012 | 08:01 AM
  #22
CACHE KRAWLER's Avatar
So again yesterday, I had to cancel my Appt with the stealership due to work issues but am getting ready to head in pretty quick here. But I wanted to post this up.....yesterday I drove all the gas out of my Jeep and refilled with 92 octane and the dieseling/ratteling sound completely went away. Within a mile the noise had dissappeared and even taking off from a stop in 2nd gear there is no noise. To make sure I wasn't just imagining things I had my wife drive (which is the ultimate test as she never listens to the engine while shifting). It is noise free but I will bring it up with the stealership and see whatthere two cents is on it.
Old Sep 6, 2012 | 05:43 AM
  #23
09jaykay's Avatar
Originally Posted by 09jaykay
My truck sounds like a diesel when i first start in first gear. its done it pretty much since day one never really though anything of it. My truck also has a rattle when under a load, I'm pretty sure its the throw out bearing, ive check all the heat shields and everything and i can't find anything loose at all.
Just an update, ive switched my truck over to only run on 89+. and the noise has stop complete
Old Oct 2, 2012 | 03:55 PM
  #24
2007wrangler's Avatar
My 07 doesnt like regular gas eather, the higher the octane the better.
Old Oct 7, 2012 | 07:13 PM
  #25
DeucesALLin's Avatar
Wow...i thought i was losing a U joint!
Old Oct 8, 2012 | 05:47 AM
  #26
It sounds like you guys are experiencing spark knock due to carbon build up.
The best carbon remover I have found is called Yamalube Ring Free. It's made by Yamaha & primarily designed for 2 stroke outboard boat motors, but is safe for 4 stroke motors as well.
I use half a bottle per tank of fuel.
It cost $20 & can be found at Yamaha boat supply dealers or even motorcycle dealers that sell the Yamalube line.
Old Oct 8, 2012 | 06:33 AM
  #27
Default Seafoam...
I cleaned my TB with Seafoam, ran 1/3rd bottle in the crank case and 1/3rd in the vacuum line- dropped my idle by nearly 400 rpm with almost NO smoke.
Old Oct 8, 2012 | 07:25 AM
  #28
Ryan0260's Avatar
Chrysler combustion chamber cleaner. $10 a bottle and is sprayed directly into the throttle body. Way better than seafoam at reducing carbon deposits
Old Oct 8, 2012 | 10:37 AM
  #29
jmpjk's Avatar
Mine has the rattle noise as well. Mine is mostly in fourth gear but I get it in second and third from time to time. Mine has a diesel sound under the Jeep too. Seems like when a compressor kicks on it does it then shuts off. I am going to try 89 or 91 octane next. Mine is a 2012 with 8003 miles! I want my TJ back......
