Diff ? should i be concerned?
The dealer resealed my front diff because every bolt had seepage around it , but 2 dealer both said the rear one is not bad and no reason to be concerned it is only 2 bolts one you can not see and pic.What do you guys think?
I wouldn't worry about that, just keep an eye on it. Next time you change the diff fluid just pull the cover off and re-seal it yourself. Not a tough job at all but the dealers seem to over charge for this task for some reason.
both mine were much worse than that... had the dealer re-seal and it still did it... I just did it myself and no problems anymore... get a high temp RTV or gasket and do it yourself.
I am pretty sure the dealers simply have some moron hose it down with a supersoaker filled with rtv...
