A different gAScap light question
You won't get a light until the system pulls a vacuum test, at which point it will fail and the light will come on. If the computer sees you recently filled the tank, it will assume it's a loose gas cap and throw the code for that before it will throw a code for another reason.
If you haven't recently filled the tank, it will throw the code for a generic vacuum leak.
